WLAN Wizard FOR N80 nokia
3 replies · 11,527 views · Started 04 November 2006
ok i have tested this on my N80 and it worked fine
so heres the address
h**p://europe.nokia.com/A4195015
Is there a WLAN network out there? The WLAN Wizard will tell you, store it and launch it for you! WLAN Wizard shows the available WLANs in the range of N80 Internet Edition directly on the idle screen and it is possible to start web browsing immediately. WLAN Wizard also automatically creates the needed WLAN settings making WLAN usage extremely easy
i have a silver n80 firmware something 3.
enjoy
SORRY ABOUT ANOTHER THREAD, I GOT HOT HEADED , NEVER AGAIN 😊
yep, works on my standard N80 also 😊..., although on standard edition I dont see the notification of the wireless lans on the screen
the icon is a blue circle, it maybe in connection or my folder
but if u look in the folders, its 100% there
one thing i noticed, my friend installed it on his black n80, it worked fine until he restarted his phone then an error came up saying app cant start something
"srv" delete.
? dont know
but it works on my silver n80 firmware 3.
will look out for some more n80 internet stuff,
my friend has a n80 internet edition, but how do i go about ripping the software from it ?
6six6 wrote:the icon is a blue circle, it maybe in connection or my folder
Yea i see the icon, I just meant that on the internet edition when it finds wireless networks it shows you the wireless networks n range on the standby screen, but on the regular N80 it doesnt show the wireless networks on the standby screen
