4.26 and BAFO V6102F IR adapter don't work!
1 replies · 1,622 views · Started 11 December 2002
I upgraded my firmware from 3.16 to 4.26 and now my BAFO IR adapter won't recognise the 7650. It recognises the other phones I have, and the IR from the 7650 works with all other phones - so neither adapter or phone is broken. I use XP Pro. Anyone used BAFO/XP Pro or had similar problems? How about ways around this? Thanks
WinXP might install some little drivers for the phone - try uninstalling the IR device and everything related then reinstall - Should work!
