Nokia N70 Uninstallation Problem
3 replies · 1,458 views · Started 05 November 2006
few days back I had installed a software called Smartguard Pro........after installing I locked my sms folder in that........now the software is not running...whenever i try to run this app it does not open...now the problem is I cannot unistall the software also.......whenever i try to unistall it....is askes for close all applications.....and when i click yes......after sometime it gives unable to remove.......even if u try to install the software over it again...it asks for replace it ...but then later on it gives unable to install.....therefore neither i can unistall or install the software so that i can unlock my sms folder........
Now please help me guys what should i do........
I had installed the software on my MMC......
Should i format my card......or is there any other way out.....
please help me..........
thanks..........
bye.....
You can install again, and a remove after. Or, search for siganture program with FExplorer, and end the open process!
the same software cannot be reinstalled or installed...whenever you try to reinstall the software over it ........it gives the error .........installation failed..........and if u try to remove it...........it shows cannot remove...........
It can be installed again. The message appears about SW version, but You can rewrite over previous installation.
