Smartphone to Google Calendar
6 replies · 2,279 views · Started 06 November 2006
Thanks to those who emailed in about GooSync, a free service that uses SyncML to synchronise your S60 or UIQ Calendar with your Google Calendar. Looks pretty simple to use, too.
Anybody know the settings for a Sendo X? It's not listed. Setting up the profile requires:
- Bearer type internet/wap
- Access point (presumably my usual GPRS access point)
- Host address (presumably the url provided by Goosync)
- Port (set to default 80)
- Username (presumably the one provided by Goosync)
- Password, ditto.
- Calendar, 'Yes'
- Remote Calendar (presumably 'Calendar'😉
- Http authentication yes/no
- http username
- http password
i've tried it on my n80, but i've some problems now!!
i reg on goosync, then i recieve n80 configuration over the air, but when i try to sync using wlan connection, it gives me a system error...:con? :con?
somebody else who has already tried it???
plz help me...i need it!
