how to install games on my nokia 3250?
1 replies · 2,556 views · Started 07 November 2006
hey every1............i would like to know how to install new games to my new phone nokia 3250?particularly a .zip file or any other file.....i would jus like to know how to install it?thank you😉
well there is 2 ways that i can think of first of all you need a .sis file or .jar file that is compatible with your phone. .jar is java and .sis is symbian. You can install most java games onto your phone but not all symbian because the 3250 is symbian series 60 v3.
Anyways first install nokia pc suite and install drivers and stuff after plugging in your 3250 with usb. Then go to Install applications from the nokia pc suite menu select the application you want and hit the arrow and it should start installing and then you have to install it from your phone just hit yes over and over.
The second way you can put the file directly on your phone with the nokia phone browser after that go to file manager in organiser and select the file you put on and it should automatically start installing.
Hope this helps.
