problem with ngage
3 replies · 1,279 views · Started 07 November 2006
I Have A Problem In Conecting Ngage To Pc
I Installed Th Pcsuite From Nokia Site
But It Didnt Work It Cant Read The Phone
Must be PCSuite for N-Gage. And the connection must be by bluetooth, so need first a pairing process.
First of all the normal pc suite won't work with n-gage but u need one of the 2 individual n-gage pc suites 4 the n-gage qd( rh-29&rh-47 ).Check ur version by entering *#0000#.Dwnload the appropriate suite from http://www.n-gage.com/en-R1/support/Software/pcsuite.htm
1)if u use a blutooth dongle with inbuilt windows xp support(assuming this is ur os)
just pair ur phone & u'r on ur way.
2)if u use bluesoleil, pair ur phone, refresh services, click on the blutooth serial port service icon till it gets connected, check the serial port used(COM7 for me),
right-click on mrouter in system tray, select properties,check the 'cable' connection with the COM port obtained above.Check if the serial port connection is still present & u'r on ur way:icon14:
