My brand new Sony Ericsson P990i is not detected by the supplied mRouter software and as a result, I am unable to synchronise my phone with my PC.
The P990i is identified correctly by the PC and file transfer between the PC and the Phone Card works perfectly (i.e. I can open the Phone Card icon and drag/drop files to/From the Phone Card) - guess this means that the USB connection is working ok.
I have downloaded the latest version of PC Suite and the Developer Version of mRouter (which allows detailed logging of errors).
When attempting to connect to the P990 via Bluetooth, the following error appears in the connection log:
wsockhost initialized OK
Waiting...
Winsock Error (tcp): hr=0x8007271D
This same error code appears for both USB and Bluetooth connection attempts.
I have tried disabling the Anti-virus software, Spy Detection software and Windows Firewall, but this has no effect on the problem.
In Bluetooth mode the phone appears to connect, shows 'connected' for a split second but then immediately disconnects (each attempt causes the error message "Winsock Error (tcp): hr=0x8007271D" to appear in the log).
I have also tried uninstalling all Sony Ericsson and mRouter software then removing any artifacts relating to "Sony Ericsson" from the registry, rebooting then doing a clean install of all software, rebooting again then connecting the P990i.
For reference, my environment is as follows:
Operating System: Windows XP Pro SP2
PC Suite: v1.2.15
mRouter software: Developer Edition v3.1.042
Anti-Virus software: NOD32
Firewall: Windows XP Firewall
Spyware Detector: Webroot SpySweeper
This is very frustrating! Has anyone else experienced this problem and found a solution? :con?
Cheers,
Steve
P.S. I have previously used PC Suite and mRouter on this PC successfully for both the Sony Ericsson P800 and P900, but the version of the software for these phones has been fully uninstalled before loading any of the new software.
When I connect my old Sony Ericsson P900 via USB or Bluetooth, the new mRouter identifies and connects to the phone immediately so I guess mRouter is working ok - it must be the P990i...?
