Some info to share with you guys.. 😊
Changes from 5.34 to 5.54
Mail:
-"Send as mail" option now available in contacts and calendar immediately after mail account created
-Email notification message, number of received emails is now shown correctly
-Default mail account is not used automatically for all reply and forward mails
-Mail connection and viewers improvements
WAP:
-WAP address with port number and without http:// supported
Clock and date:
-Time & date setting dialog added to startup, if conflicts notified with time & date
-Minimum date set to 1.1.1985 (previously 1.1.1980)
-Clock time & date functionality improved
Call and network management:
-Fax call handling improved
-New call handling simultaneously with active call improved, when using fixed dialling
-Call diverts and Recent call lists functionality improved
-Improvements for call answering functionality
-DTMF sending reliability from PDA side improved
-Call cost handling improved between phone side and PDA
-Phone side earpiece volume levels increased by 4 dB
-Indicator, display notes and other notification functionalities improved
-Secure proxy support added
-Improvements for document handling and opening files
-Minus (" - "😉 separator can be used for IAP phone number
-Improvements to Lock code functionality
-Welcome notes prioritisation improvements
-PIN code functionality improvement: able to enter PIN from phone side in case switching to another country and manual network selection is selected
-Secure memory card: Paste function disabled from password dialog
-SMS alert volume: if several messages received at the same time the volume for new SMS alert is as set in profiles
Calendar booking improvement:
-If Cal booking message received in two parts and parts are coming in wrong order; the cal booking message is received correctly
-Improvements to WWW browser
-Operator list updated
interesting..! it's time to visit the Service center here 😃
5.54?
When did this come out?
Phoned the service center here and they are normaly very good. But they dont know about it.
it was here 10.12.. so could take couple days to reach every local service centre.
Edit: date fixed..
Nokia tells me that it is not out yet... 😮
here it will help you
http://www.nokia.com/NokiaHome/0,5184,4914,00.html?
also put new allnokiadata.sis on the 9210i
Sorry, to be sure I understand this right...
1) Firmware - phone has to be sent to a Nokia Service Centre for the upgrade from v5.34 to v5.54.
2) Will the Nokia Service Centre also install the other files contained in
All_Nokia_data_EN_554.SIS ?
3) If no, am I correct to assume that you have to do nothing apart from install the file All_Nokia_data_EN_554.SIS? Does this automatically overwrite all the older versions? Does it matter whether the individual applications included are split between communicator and MMC drives?
4) I assume All_Nokia_data_EN_554.SIS should not be installed on 9210i v.5.34 ?
Have I got this correct?
Has anybody done this yet? Was it worth the effort?
Thanks for your help.
for this it is the reason
the sis file have to installed by your self
in holland several people have done it already
Is it worth to up-grade to 5.54? 😮
in my country upgrade is free if the warranty is still valid.
go for it. upgrades are improvements
Nokia says it's still not ready for my country! :evil: They have even advised my not to up-grade if my current software was doing fine!!! 😮 :-? I do not understand this!!?? :x What should I do? :-?
is this upgrade avalaible for the 9210???not the i😊
Latest(hope not last) software version fo 9210 is 4.13.
4.14 9210
5.whatever 9210i
So? Yoy think it's a good idea to up-grade?
Condidering the improvements anounced, I would have do it allready.
It is up to everybody 😉
Well,i'll guess i'll up-grade 😃 ...I'll take the chance of cleaning my 9210i. 😊
What about 9290? That's the one we get here in Mexico.. but I didn't find those upgrades
Probably nothig yet... :-?
Which is the date of version 05.54 (9210i)
22-10-02 ??????
I have 5.34 on my 9210i...I suppose 5.54 is the one you typed more or less.
So, does anyone here have personal experience of doing the upgrade from 5.34 to 5.54?
Was it worth the trouble?
Unfortunatly no!! I was hoping to hear some words...
It's weird,the nokia ignorant people here in my country suggest not to up-grade unless you have serious problems with the previous versions!!!???
I really don't understand their behaviour...
Did the upgrade.
Have not noticed anything major improved. Oh well.
All i know is that 5 days later my phone died! Though this could be somthing else. Though i have never had a problem wityh the phone b4. And nokia have had it for the last 3days now tryna fix it! Though they just called and said i can get it today yippy! (Only 3 days i am impressed hehe!)
it is advisable not to fix something that ain't broke coz u risk the possibility of having problems with the new version, i'm sitting this one out waiting for updates as to whether the new version is indeed a better version.
