Quickstart icons on screensaver ????
3 replies · 2,542 views · Started 09 November 2006
I've just updated my N80 on O2 to ver 4 firmware using the "change product code method". I know it takes away all the O2 stuff but i want to get rid of the row of quickstart icons of my screensaver.Also does anyone no what is on the bottom left and bottom right of the standby screen on O2.When i updated they have changed and i want to put them back to O2 settings.
One more thing,when i changed the product code should i now change it back and if so what is the code for N80 on O2??
Hope you all can help and many thanks in advance.😊
I'd change the code back if you plan on ever letting O2 or NSC get hold of it... if your the only one to see it then dont bother and do it at a later date should you need to... either way, its not hard to swap the code (so long as the phone is in full working order)
As for the right /left soft buttons, from memory it was MMS and the word O2 on mine.
Do you happen to know what the code would have been on an n80 on o2???
When i changed it the program did'nt show the original code !! THANKS GARY.:con?
