MP3 Player required
0 replies · 2,220 views · Started 10 November 2006
I am after an MP3 Player to replace the music library player on the N73. I have tried to use the one that comes with the N73, but find it awkward to use.
I have an audio book that I want to listen to, and therefore hundreds of files, but unfortunately, it seems that the music player does not want to put them in any particular order, and there does not seem to be a way of doing it. The files are in file format CH 01x25, CH 01x26 etc... but they do not display in order, the only way I have found to do it, is to create a playlist, and then add each one in indivdually.
I would like something like TCPMP, which I used to use it on a Mobile device.
Can anyone help, and send me some links.
