N80 on O2 Original product code????
2 replies · 2,316 views · Started 10 November 2006
Ive upgraded my software to ver 4.*** using the change product code method.If i have to take it to nss then i will have to change it back,does anyone no what the original product code is for n80 on o2(UK) Thanks in advance.🙄
If you'd read it all properly you'd have noticed that your original code is written on a label on the phone under the battery.
And *oopsie* on your double post btw 😉
GarysN80 wrote:Ive upgraded my software to ver 4.*** using the change product code method.If i have to take it to nss then i will have to change it back,does anyone no what the original product code is for n80 on o2(UK) Thanks in advance.🙄
I would advise you to change back the Product Code NOW because if your handset develops a fault you might not be able to change the code before taking it into an NCC, and if they notice your code is wrong your warranty will be void.
P.S. As stated by others, the original produce Code: is on the label behind the battery on all Nokia phones.
