My Sony Ericsson P908 mobile touch screen does not respond when I touched on the screenn using my stylus. why is it ? How can make it active using jogdial or what shall I do? Please help me.
touch screen problem
hey, man
i am in canada, i got the same problem for the touch sreen.du u know where we can send this product to be fix?
thanx ...
I would suggest you back up your data on the PDA, do a format and system restore then install updated SE software. If this fails I would then look into the possibility that the PDA screen needs replaced, or there is some other major fault.
Have you accessed the service menu that checks out the functions on your PDA?
