The subject says all. The same Java applications runs on N73, n70, N91, 3230 but when I try to install on N80 - last firmware version - says almost on end installation - unable to install. Why? I try almost all I remenber :con?
I search on forum, and I found the same question for N73, and I think not for N80. Thanks!
Why I was unable to install Java applications on N80???
Well besides the N73 all those other phones are S60v2 which means even if you do manage to get the apps running you'll have some substantial graphics problems (you tend to find bits of offscreen buffers and the like being rendered to screen)
No exactly! N91 is S60v3. And some of that Java have downloaded for N80 (dedicated applications) like Opera mini and eqo.jar.
