Psiloc Screen Saver Bug?
16 replies · 3,675 views · Started 12 December 2002
I have got this message appearing 😮
App. closed
sSaverDaemon
W32 5
I have chosen an animated Gif for my screen saver.
This error message will appear out of no where.
No background application are running.
Looks buggy to me. 😮ops:
Any idea what could have cause this.
Yes it does animates.
The Screen Saver works perfectly.
I am curious what does that error means.
Although I can't change anything, I want to bring this out to see whether anybody else also had this error message.
At the same time to bring Psiloc attention.
By the way, do you have Screen Saver yourself?
I am uncomfortable to have error messages popping out when I paid for it.
I had the trial, but dont want it.
takes precious space and is totally useless and sucks up battery mighty fast 😃
Would not use it even if free 😞
cant give any solutions but have a couple of things to share. a friend of mine had the same problem. he gets the same error. so what he did is unintall the app and re-install again but the problem still persists - worse it affects his SeleQ. i dont have a clue of all apps why seleQ but everytime he has the ssaver installed and he tries to access the SeleQ doesnt work and the phone will eventually hang.
this happened over a couple of times and so he decided to ditch ssaver (plus for reasons stated by jyrik) and he reinstalled SeleQ as well.
whew, good thing this has not yet happened to me. i have ssaver and it runs ok. 😃
also had the same message on my phone as i was trying screensaver! what i did is uninstall it and never install again !!! that's the solution you might wanna think about!
[quote="kobe24"]And I thought you were convince by jyrik[/quote]
actually, there was a period of time i did ditch the ssaver! but now that SDoubler is around i have it installed and packed. i rarely use the screen saver options, i use the default date and time, it's just there in case i need to show off my phone to friends who didnt know about AAS and the other awesome stuff this phone can do! Ha!
😃 8) 😃
Yeah. so many stuff to pack into that precious little space...
Which makes me wonder, why is it almost the same price as the new 7210 phones. I mean we have a Symbian phone!!!
Hi again,
Does anyone experience having the original screen saver overlapping
Psiloc's screen saver?
Or is there a way to only have Psiloc screen saver only. :-?
I had it occationally while I was using Screensaver, but as mentioned earlier it uses to much resource and is a waste of space, so no more Screensaver, no more problem.
:fadein:
Thanks Bob! 😊
Hmm,
Psiloc Screen Saver is really buggy then.
Hope Psiloc will do something about it.
As I can see, the Screen saver timeout of the phone original is used
in Psiloc as well.
If they could separate them, meaning Psiloc timeout time could use another timeout time and not sharing with the phone original timeout time.
In this way, the pics will not be overlapped.
Did anyone brought this issue out before or its been discussed before?
