Any way to force an app to close?
1 replies · 3,541 views · Started 12 November 2006
Occasionally on my N73 an application locks up. I can switch back to the 'desktop' by pressing the red end call key, but the application is still running in the background if I bring up the task manager. I can't close the app by opening it as the screen freezes again - is there a ctrl-alt-del type equivalent to force it to close?
cheers
Jon
With task manager, the most equal to "ctrl-alt-del" type is press the C key!
But, sometimes it works, sometimes don�t!
