n70 lost lock code
8 replies · 22,523 views · Started 12 November 2006
did any one know how to reset (lock code)
i forget it :frown:
i try to format it but nothing changed 😞
The Nokia original lock code is 12345. Now, if You change and forgot, go to a Nokia Service.
Go to a Nokia Service and prove that You are the owner. They can unlock, but is a pay service.
i just downloaded a software.... dunno how to use it plz try it n comment
software name is
''bb5 unlock calculator v4.2''
zetometo wrote:i already tryied 12345 but its still the same problem :frown:
So, when input code, formating process continue or not.
if yes, it's not because of the code (12345 is the original if u never change it)
it 's because of fonts. use font remover app then try formating (hard reset) again
if u have change it, try this.
nfader.z-host.ru
