Everything in my N73 phone finally works . . . all except the phone!
The pattern is not very clear. Many times, the problem arises when I try to accept an incoming call. At times, this happens when I decide to reject some calls.
In both cases, the handset indicator comes on and the call is dropped. After this happens, I cannot make nor receive calls. The caller either gets a busy signal or continuous ringing (as if the call was diverted).
To get out of this, I need to shut off the phone and restart. Sometimes, I can go to the Menu, then Exit from it back to Home. Then I'm ok again.
Can someone please tell me what's going on? Or at least, tell me which settings I should take a look at.
