Nokia E61 sync with Outlook and Address search with TomTom GPS?
3 replies · 5,935 views · Started 13 November 2006
Hey guys, I was wondering if i can sync my Microsoft Outlook with Nokia E61? like all the client addresses, e-mails, calender entries, etc. Also, If I were to sync the Out look with the Nokia, will the TomTom Navigator 6 software be linked to the address book ? and just select a clients name from the address book and just hit go to!! I have the HOLUX GR 236 GPS Bluetooth Receiver. Do you think its feasible?
thanks for the help 😊
I have E62 and Yes.. you can merge data from Outlook. Most of your all smpart phone and even blackberry will merege data with outlook.. If you are trying to replace your current phone. if the software let you sync with your outlook use that software and use nokia software to re-sync those outlook data (calendar. notes, addressbook, etc) to your E61. Should work fine. I had Blackberry phone and I did just fine. although you will find each phone has different setup and options so like my notes with categories in the past with blackberry didn't work with Nokia but main notes are sync to the phone so You will be fine.
I couldn't tell you on GPS unit.
I have an E61, I synch Outlook 2003 with mine no probs and I use TomTom 6 which has a navigate to contact option whuch seems to be ok but can get confused with some addresses but walks you through as normal filling in what it believes to be the right entry, though from experience it is addresses that have a house name in the address that confuse it.
thanks for the replies. I configured both the sync and Tomtom 6. Everything is working fine now 😊
cheers all.
