Joystick Broken Off
6 replies · 3,312 views · Started 14 November 2006
After about 2 weeks of owning the N73 my joystick just broke in my coat pocket. I dunno how exactly it happened but the joystick broke clean off. I managed to fit it back into its palace but its broken now so i need to go back to the shop where i got the phone to get it exchanged.
Anyone else suffer something similar?
This is a known manufacturing problem. Basically, the glue used to hold the joystick top on isn't very good.
I re-fixed mine with some decent superglue, and haven't had any problems with it since.
And, of course, a Nokia repair/service center should replace such faulty components under warranty.
Are you sure it's the whole thing? If it is, then this is NOT what I was talking about.
The joystick mechanism itself is pretty sturdy - all I've seen is the silver top to the joystick falling off.
Yes, Nokia will replace the joystick under warranty!
