Hi
I have firmware version 4,13, and all software installed correct, on the MMC card, etc. When I try the holp button however, I get an error message... "Note! Not found..." I have reinstalled Help.sis many times to no avial.
Please help guys, as I am about to give up!
Regards
lupo
No Help!
Damn I see the same message, but with other apps (see my post "Help about sending ring tones via SMS"😉... And some people get this message with eMessaging (see post about eMessaging on www.My-Communicator.com)...
And now you get it with the Help...
Does anybody understand it???
may be there is the information for an older version in the software list..
had a similar problem with video app.
be shure that every version is deinstalled and take a look into the app folder on the communicator if there is a folder for the app also after complete deistallation of every version.
if there is still a folder.. delete it before installation
hope this works for you
telepong
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2002-02-06 1518, Manowar wrote
Damn I see the same message, but with other apps (see my post "Help about sending ring tones via SMS"😉... And some people get this message with eMessaging (see post about eMessaging on http//www.My-Communicator.com)...
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Have you solved it allready??
No, JeP, it�s not solved already!
Nokia said me that they didn�t know why. They reinstalled 4.13 on my phone, but the message goes on...
They said they�ll call to me when they have a solution...
Regards!
Hello guys;
I do have 4.13 and i don't have any problems with the help function.
It could be a problem with one off the apps you installed???
Ren�
Hi, Rene!
I thinked what you say,and I formated completely my device and installed only the nokia data.sis files, but the problem continues...
Regards and welcome!
