When are the Memory Stick DUO 128mb arriving in stores?
14 replies · 5,617 views · Started 12 December 2002
If the P800 is going to be used as a mp3 player, I want at least 128mb of memory at my disposal.
http//news.com.com/2100-1040-977004.html?tag=fd_lede2_hed
Buy a second batery with your 128mb card (when you find it) wink
[quote="Afonso"]http://news.com.com/2100-1040-977004.html?tag=fd_lede2_hed
Buy a second batery with your 128mb card (when you find it) 😉[/quote]
This is an article about a new memory stick format; memory stick pro, and not memory stick duo.
Yes, but since you said "at least 128mb" this article is to show that probably capacities bigger than 128mb will show up in this new (yet another Sony fragmentation step MS, MS-MG, MS-Duo, now MS-Pro) PRO format wich most probably the P800 will not take.
The only thing that made me *swallow* the proprietary MS-Duo card of the P800 is the tought that trough BlueTooth I could always get some degree of off-the-air information portability between devices.
This latest Sony's MS-Pro stunt only stressed to me how important it will be to guarantee that the P800 will be able in fact to change files BT-wirelessly. I have put my P800 buying intentions on hold until confirmation that BT firmware works as advertised.
[quote="Afonso"]YPRO format wich most probably the P800 will not take.
[/quote]
you're quite right, I just downloaded the final version of the user's manual
http://www.sonyericsson.com/downloads/P800_UG_R1a_EN.pdf?traceClick=yes
and it says on page 185;
additional storage
Memory Stick Duo, up to 128 mb supported
32 and 64 mb will be realesed on the 10th of February
128 mb will be realesed on the 21st of March
Official realese from Sony
[quote="DmX"]32 and 64 mb will be realesed on the 10th of February
Official realese from Sony[/quote]
Have you got a link to where you got this info?
If it's true, I gotta start saving... First P800, then Bluetooth Dongle, and then a 64 Mb MSD...... Damn....
yea i have the url but not in english!
http://www.sony.jp/CorporateCruise/Press/200212/02-1210/
[quote="Rear_Admiral"][quote="DmX"]32 and 64 mb will be realesed on the 10th of February
If it's true, I gotta start saving... First P800, then Bluetooth Dongle, and then a 64 Mb MSD...... Damn....[/quote]
I talked to the swedish Sony Ericsson suport yesterday and they said that 16 MB and 32 MB sticks will be released in the first quater in 2003. More than that he didn't know for sure. According to that, the info from DmX could be completely true.
But remeber that it could take a while for the sticks to reach Sweden.
[quote="Nidom"][quote="Rear_Admiral"][quote="DmX"]32 and 64 mb will be realesed on the 10th of February
But remeber that it could take a while for the sticks to reach Sweden.[/quote]
I see at http://www.nowelectronics.biz/s/Side_Bar/Lexar_Media_128_MB_Memory_Stic_B0000691IO.htm about memory stick 128 MB. You think that works on P800 ?
Wrong size. That's a regular memory stick.
You need a Memory Stick Duo, about half the size of the normal one.
Check out this site. They deliver internationally. I got my Brando screen protector from them
http://shop.brando.com.hk/memorystickduo.php
[quote="Durzel"]Wrong size. That's a regular memory stick.
You need a Memory Stick Duo, about half the size of the normal one.[/quote]
Why sellers don't write clarely if a memory stick is DUO or PRO or some other kind ???
Well, if I understand well, Memory Stick Duo 128 MB were released in April 2003 ?
