The sound of 7610
2 replies · 1,902 views · Started 15 November 2006
Can anyone tell me how to make the music of my 7610 from the speaker and earpiece to be stereo?? coz i hate the mono sounds...😡
Kindly giv a solution...thx in advance
You simply can't. The hardware would need big modifications which cannot be done. Get used to it or change your phone.
:icon14: first try to change the formate of the sond to wav on computer with any program like audiograber
then open this file with windows sound recorder (present in programmes , accsesories , intertainment , sound recorder )
from effect menu pres " increse volume by 25% " and do this several times
thus you have very high souns file save it then convert it to mp3 with the audio graber again to get small file
that is all
happy to see your comment
[SIZE="6"]noga[/SIZE]
