Ringtones
8 replies · 2,866 views · Started 12 December 2002
I read somewhere on this channel how to increase ringtone volume (something converting and editing?). How can I do this, without fancy software? Also, since this topic is all about ringtones, I'll fire a few questions :
*What extention are polyphonic ringtones, and where do I get some?
*Is midi, polyphonic, wav or amn louder/clearer? Which is best?
*Can one send ringtones via IR?
*Can one convert between these formats?
polyphonic ringtones = .mid
Yea, you can send the through IR (well, at least through BT, so most probably the IR too 😉)
There are free softwares to increase the volume of midis.
Amr to wav, yea you can convert, but with a loss of quality.
I like midi ringtones the best.
[quote="Dolby2000"]I read somewhere on this channel how to increase ringtone volume (something converting and editing?). How can I do this, without fancy software?[/quote]
You mean that bug in fw?? do a search :P 😃
[quote="Dolby2000"]*What extention are polyphonic ringtones, and where do I get some?[/quote]
I think those are basically same as midi's
[quote="Dolby2000"]*Is midi, polyphonic, wav or amn louder/clearer? Which is best?[/quote]
wav is louder, but i like midi's better. :P
[quote="Dolby2000"]*Can one send ringtones via IR?[/quote]
Yes
[quote="Dolby2000"]*Can one convert between these formats?[/quote]
Yes. do a search in series 60 multimedia
I can't seem to find anywhere where I can send the midi ringtones via IR *blush* Could someone help?
Or select it in recorder and send>via infrared ... Or that could be just .wavs or what ever... Any way just use this
[quote="MaleBuffy"]Zipper can you please link to the file and not upload it everytime you refer to it? Thanx[/quote]
Sorry, Did I post it twice? My apologies
[quote="Zipper"][quote="MaleBuffy"]Zipper can you please link to the file and not upload it everytime you refer to it? Thanx[/quote]
Sorry, Did I post it twice? My apologies[/quote]
no you didnt. he was just asking you to link instead of posting again. 8)
