logdbu.dat
20 replies · 4,678 views · Started 12 December 2002
I asked this once, but perhaps someone does know it by now .. 😊
At c/system/data I have a file named "logdbu.dat", which is 157 kB large ... and increasing day by day. I have no idea what this is for ... sounds like some log file or something like that. I would like to delete it - I guess nothing evil will happen ... but I'm not sure ... 😮nfire:
Anybody can help?
Its used by the Log of the phone, you cannot delete it! You can even copy it! Anyways, even though I cleared my Log the file is still about 40kb and I opened it (from a backup on the PC) with notepad and it showed some numbers I called and stuff. Its definately from the Log and is deleted I guess like a recycle bin..when it needs to be deleted!
[quote="MaleBuffy"]Its used by the Log of the phone, you cannot delete it! You can even copy it! Anyways, even though I cleared my Log the file is still about 40kb and I opened it (from a backup on the PC) with notepad and it showed some numbers I called and stuff. Its definately from the Log and is deleted I guess like a recycle bin..when it needs to be deleted![/quote]
Normal behaviour of SQL databases... When it is compressed by the database all the deleted stuff will go away - though I don't know how often Symbian OS compresses its databases.
ok, I got it, thx a lot! In the German menue its called "protocol" and not log and so I didnt see what logdbu could be ... 😊 ... cleared all logs and the logdbu.dat now is 3 kB ... saved 150 kB! Great!
Does this actually take up the usable amount of memory!? Ie the amount of space I have to put apps in? And by log we are talking about the Call logs right?
Yes it does take usable amount of memory,its stored on the C: drive.
But you can clear your logs and regain it in no time.
And yes,we are talking about call logs.
[quote="Zipper"]Does this actually take up the usable amount of memory!? Ie the amount of space I have to put apps in? And by log we are talking about the Call logs right?[/quote]
yes, yes, yes 😃 😃
[quote="seanmiguel"]one other thing you can do is set the log to 1 day. i do that and maintain 23-25kb for that file.[/quote]
A day? Then what is the point in loging?
[quote="Anonymous"][quote="seanmiguel"]one other thing you can do is set the log to 1 day. i do that and maintain 23-25kb for that file.[/quote]
A day? Then what is the point in loging?[/quote]
The issue is to reduce the space occupied by the log files and it was one suggestion. You can't eat the cake and have it too!!
[quote="sanjay2402"][quote="Anonymous"][quote="seanmiguel"]one other thing you can do is set the log to 1 day. i do that and maintain 23-25kb for that file.[/quote]
The issue is to reduce the space occupied by the log files and it was one suggestion. You can't eat the cake and have it too!![/quote]
There is an option to set the log completely off. That makes more sense indeed than logging one day ... 😉
[quote="sanjay2402"]...You can't eat the cake and have it too!![/quote]
i still dont understand and see the logic in this phrase....since i was a child :P 😊
If you eat the cake, you no longer have the cake, therefore you "cannot have your cake and eat it".
[quote="Bob"]If you eat the cake, you no longer have the cake, therefore you "cannot have your cake and eat it".
😉[/quote]
what if its a big cake and you only ate a slice of it? 😃
oh talking about cakes...its my birthday on sunday :bday: 😃 ...hint 😉
Then you could have some cake and eat some cake, not the same!
:P
Happy B'day for Sunday, p.s. how old will you be?
B
[quote="Bob"]Then you could have some cake and eat some cake, not the same!
:P
B[/quote]
Correction. That would be eat some cake, share some cake (not much left to have) :P
Happy Birthday Bezanime :bday: :bday:
