I have Blackberry Connect (Enterprise Edition) running smoothly on my E61 but the calendar sync does not do Tasks. Unfortunately PC Suite does do Tasks but only when you sync calendar entries. ! If I do sync calendar entries via PC Suite I get duplicate entries... So the question is: is it possible to synchronise Tasks to my E61 without buggering up email and calendar synchronisation?
Thank you
I don't use enterprise server on my e62 but I had issue with attachment on jpg for non enterprise server user and I had some converstion with RIM.
I heard version on blackberry connect on nokia is not same version software as blackberry phone so.. maybe something is effecting.. I would call RIM.
these link don't help much but you can see some chart on blackberry services..
Below are links to Knowledge Base Articles that are related to issue associated with this case:
What Is - Supported attachments for BlackBerry Internet Service
http://www.blackberry.com/knowledgecenterpublic/livelink.exe/fetch/2000/8021/270925/What_Is_-_Supported_attachments_for_BlackBerry_Internet_Service.html?nodeid=722744
What Is - Feature comparison for the Nokia device with BlackBerry Connect integrated with the BlackBerry Internet Service
http://www.blackberry.com/knowledgecenterpublic/livelink.exe/fetch/2000/8021/707659/706158/What_Is_-_Feature_comparison_for_the_Nokia_device_with_BlackBerry_Connect_integrated_with_the_BlackBerry_Internet_Service_.html?nodeid=1199925
i dont use blackberry personally but there may be some info here
http://www.businesssoftware.nokia.com/blackberry.php
Thanks for your input guys !
I haven't found a solution yet, any other suggestions ?
Thank you in advance.
Tiramisu
