NEW: SmartvCard !
1 replies · 6,568 views · Started 12 January 2003
Connect your Nokia 92xx Communicator to the worldwide standard of contact data exchange! Read more here
SymbianWare's SmartvCard application provides easy and comfortable import/export of your contacts to vCard files.
What is vCard?
vCard automates the exchange of personal information typically found on a traditional business card. vCard is used in applications such as Internet mail, voice mail, Web browsers, telephony applications, call centers, video conferencing, PIMs (Personal Information Managers), PDAs (Personal Data Assistants), pagers, fax, office equipment, and smart cards. vCard information goes way beyond simple text, and includes elements like pictures, company logos, live Web addresses, and so on.
Why do you need it?
1. You can export your contacts from your PC Contacts manager (almost all known programs dealing with contacts understand this format) and then import them to your Nokia 9210 easily with the help of SmartvCard in convenient, customizeable and fully controlled way.
2. Also you can export selected Nokia 9210 contacts to .vcf file to be easy imported to your PIM, Contacts manager, eMail client or any other program of such kind.
3. May be you want to make a backup for your contacts? Just export your contacts and you'll be able to import them again to your Nokia 9210 when they are needed.
Trial version works for 15 days without any limitations.
This is an excellent piece of software. Now I can back up my contacts to my laptop using the MMC via a USB MMC adapter (and import them). As a result I can dump the Nokia desktop PC connect software once and for all. Also, I can import VCF into Microsoft Outlook Express! So, I can dump the big bad bloated Microsoft Outlook as well.
Thanks guys! I've been wanting this software for ages. I've already paid up 😉
