This may seem a stupid question, but I can't seem to work out how to have my contacts displayed FIRST NAME, SURNAME. Can someone tell me how I change from the default SURNAME, FIRST NAME?
Many thanks!!
Many thanks!!
Go into your contacts.
Click on the pull down menu at the top of the screen (where is says Contacts V this will bring up a menu - BUT, you will have to scroll down to the bottom of the menu, then you'll find the Settings sub menu, select Sort By and you'll find what you are looking for . . . . .
Good luck
G
*Just do this before you want to sync your P990i with Outlook for the first time. 😊
I got my P990i and wanted to put 228 contacts from my 'P910 Contacts' subfolder in Outlook across to my new 'empty' P990i - you can imagine my frustration when all my contacts arrived on my phone with surname first!!
