Nokia 3230.........Solution Needed
2 replies · 1,870 views · Started 17 November 2006
Hi everyone...:icon2:
I am actually facing some problem since yesterday that is 16th Nov, 2006. The problem is that I was actually storing a number on my mobile and for that I need to type a name of the concerned person. All other alphabets are absolutely working fine. The numerical pad numbered �5� or �JKL� was working fine too but within few minutes it got blocked and I cannot type the number anymore or the alphabets assigned to that button numbered �5�. There is a beep sound with every button I press but this numerical button numbered �5� is not working nor I am able to hear the beep sound it used to make at each press just like the other buttons does. :frown:
So what is the problem? Can anyone of you let me know? How did it happen all of a sudden when I was actually typing double �L� the first �L� typed properly but when I repeated it for the second time it didn�t type? :con?
Kindly help?
Smiya...
Hi Smiya
AFA I can see, this has nothing to do with storing the number or the name of the person and can occur at any time and anywhere. It can very surely be a mechanical probem with the hardware. If you are not new to the handset and know how to do minor repair, then you can try removing the body and checking the pins on the inside of the keypad, or u should see Nokia Care center :tongue: :icon14:
Hope this can guide u a bit.
Cheers!!!
