PC Software > E70
1 replies · 1,936 views · Started 17 November 2006
Hi guys,
Anyone got a solution for my idea?
I want to be able to fire out quick SMS messages from my PC.
My idea is to use the Nokia TextMessageEditor.exe file from a DOS command.
Currently I have figured out that if I save a draft message with the number that I send messages to mostly (my wife) at c:\draft.vmg on my PC, I can issue the following command in DOS...
TextMessageEditor.exe /e c:\Draft.vmg
The /e means edit and the c:\Draft.vmg is the stored location of my empty draft email with wife's number in.
I would like to be able to do something like:
TextMessageEditor.exe /e /n079xxxxxxxxx /m"Hello how are you"
But I need to know the DOS commands for the TextMessageEditor.exe program.
I could eventually use this to create a faster way of using the Nokia Text Messaging tool.
Anyone else tried this?
