Nokia E50 - Mail for Exchange error
1 replies · 8,292 views · Started 17 November 2006
I've been testing a Nokia E60 with Mail for Exchange (MfE, M4E) for a couple of weeks and it works great.
Now I tried the same on the Nokia E50 with the same sim card and settings, but I can't get it to work. Sync stops with a red exclamation mark, without an error message. If I check the admin_log1.txt file in the MailForExchange folder the following error message shows up: "System Error -15002"
GPRS connection is OK, I can browse the internet, also tested the http://servername/oma, I can logon to my mailbox this way.
Mail for Exchange client installed is 1.3.1
Phone details: ( *#0000#)
V 06.27.1.0
10-07-2006
RM-170
Nokia E50
On the server I checked this folder:
In IE File; Open ( check Open as Web Folder)http://servername/exchange/username/NON_IPM_SUBTREE/Microsoft-Server-ActiveSync
I see three subfolders:
-NokiaE60
-PocketPC
-RoadSyncClient
I tested successfully with a Nokia E60, HTC TyTN and Nokia 9300 (with RoadSync)
There is no folder NokiaE50, so it looks like the phone is not connecting to the server
Has Anyone seen this error message and more important found a solution?
Found the solution: (on a nokia forum)
Removed the proxy settings on the gprs connection and now it works
