can anyone help me with formating the phone memory? because when i try to install the N gage game which works on nokia 6630 (Tomb Raider) my phone says memory full delete some item so for this i want to format my phone memory.
Please help I will really appreciate that
thanks
You can�t post that kind of question here. Read the forum rules.
nj7, since when it's forbidden to ask how to format a phone?
@jsmicky - *#7370# followed by accepting the reset warning and entering the lock code. This will erase everything from your phone so make a backup if you want to keep the data.
Is not formating phone memory... Is install the Tomb Raider from N-Gage on 6630. The only way, is the illegal way, and we should not talk about that on this forum, as You should know from forum rules.
He asked how to format his phone, not how to install the game.
i have problems installing new themes on my nokia 6630. When i try to install the theme it says something about security error and could not install.
it's the same problem for installing applications and other stuff on my cell.
So, can anybody tell me how to fix this or had the same problem, but now it's gone, please post anything!!😮
Go to Menu - Tools - Software Manager - Options - Sttings - "All" + "No" (the names can change, because I do a translation from my software language).
thanks bro, this means to me a lot
ok, next question😊
I installed new software on my phone via PC suit, everything was ok, the installation was fine. What's bothering me is that i don't recognize anything new on my phone, does it have to be like that, or was there something wrong in the installation, or by the meaning of installing new software is just refreshing the phone(formating it)!
please if anyone has the time to answer to this, please (again) do so!!:tongue:
On 6630 I don�t remember well where the applications go, but on N80 they go to a folder - My Apps, and on N73 they go to a folder - Applications, so search for the files on a folder like that, or if it is like old way, on bottom menu.
