okay, heres a detailed story of what happened...i click the contacts button, contacts appear,i click menu button and click properties and database properties of the device appears, it says 37 kb. i close the contacts and click the extras button then click control panelthen click memory, it shows device memory, then i go to contacts and it says 48 kb. you see, both contacts info on the same device but different size. explanations anyone?
same contacts same device different size
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Yes - Nokia are mad.
Not sure, maybe the Contacts version is amount of memory used by contacts, where as the very misnamed memory app actually tells you file size. Or maybe I don't really know as on my 9210 both contacts app and memory app report the contacts directory as 53kb each.
