messed up nokia pc suite....
2 replies · 2,182 views · Started 19 November 2006
i tried to install the new version of the pc suite.. it said it was uninstalling the old version first then i got an error box saying cannot uninsatll the nokia cable driver.... if i look in add remove progs there is the cable driver there still and it wont uninstall... i used the nokia pc suite cleaner to clean out all the old nokia crap... and re installed from fresh.. but still no joy i have this stuck there cable drive causing me problems !?!? any ideas ?! i tried to do a system restore and now the whole prog is fecked just keeps pingin up with error boxes like cannot find .dll file etc im guessing this is the nokia cleaner caused this !!! gurrr how do i fix it all !?!?lol :con?
Onis,
I suggest you use a registry cleaner program first then you start fresh again and reinstall PC suite , While reinstalling it, you will be getting on your screen a pop up window saying failure to........bla....bla.... with 3 options Cancel, Retry , Abort if I well remember.
Just click on ABORT and let it finish what it started. PC suite should be working fine when you restart your pc.
It took me almost a whole night to figure out how to work it , & at the end when I was fed up I cliked on Abort by error instead and to my surprise it worked !!!
Good Luck & let us know result
To clean registry entries, could be an idea, delete each entry of PCSuite, because the cleaning program do not do that the right way.
