What's a sniffersrv? Sometimes when I start my N80 I'm told "Unable to start sniffersrv. Application may need to be removed".
sniffersrv?
Considering the web will show you almost any illegal combination of acts involving horses and / or glass coffee tables it has remarkably little to say about sniffersrv. There are a few instances of other people reporting the problem but no one, anywhere seems to know the answer.
Fascinating, Captain.
cmcc wrote:What's a sniffersrv? Sometimes when I start my N80 I'm told "Unable to start sniffersrv. Application may need to be removed".
something with wlan, if you install wlan wizard try uninstall that app !
i'vehad the same message ever since i installed WLAN wizard too.
never use WLAN wizard anyway so might just uninstall the application.
I stopped using w/lan wizzard because I had several crashes and had to restart my phone...
Aha! Yes, the wlan wizard could well be it. I've removed it and haven't had any errors across multiple restarts, which is a good sign...
Many thanks.
