Soft Keypad, the program which allows you to use the joystick of the 7650 to enter data into your 7650 has been updated to version 1.10. Updated include support for the latest hardware and better support for T9 mode.
Updates:
In predictive text input mode (T9), the application now detects when a word is underlined for change, and pops up in the appropriate "Dictionary" mode. The menu command "Options > Dictionary" is no more needed.
This version has been tested with version 4.36 of the Nokia firmware (problems had been reported with the previous version of Soft Keypad, in normal text input mode, on this version of Nokia firmware).
Support for Hungarian and Polish character sets has been added.
More details at http://www.kylom.com/
