n80 wlan browsing problem!
2 replies · 2,746 views · Started 21 November 2006
i have connected to an access point, but whenever i start to browse a web page, it returns no gateway reply..what should i do to solve this? pls help...
You should post your Wi-Fi access point's settings and what you defined on the phone.
Otherwise it is hard for anyone without access to your router or phone to see what might be wrong.
Hi xlan,
the problem might be that your router is not set for DHCP....set the DHCP server on ur router and then it should work fine..
~Cheers.
