hi all,
can anyone give me a step by step guide as to how to store the WEP code, finally configured my fone to my orange livebox, whenever i connect to wifi i have to reenter my 26 digit hex code, any help greatly appreciated
cheers
Dean
hi all,
cheers
Dean
deano1976 wrote:hi all,Hi Dean,can anyone give me a step by step guide as to how to store the WEP code, finally configured my fone to my orange livebox, whenever i connect to wifi i have to reenter my 26 digit hex code, any help greatly appreciated
cheers
Dean
You need to define a new access point on your phone that refers to your home wifi network. There are 2 ways to achieve this:
1.) Menu > Tools > Settings > Connection > Access points > Options > New access point > Use default settings
You then need to fill in the relevant fields, e.g.
Data bearer = Wireless LAN
WLAN security mode = WEP
WLAN security setting opens a sub menu where you can store your WEP key.
2.) Menu > Connect. > Conn. mgr. > Availab. WLAN > highlight your home wifi network from the scan list > Define access point
Method 2 will autofill a lot of the settings for you under the new access point menu, however, you'll still need to enter your WEP key settings under the WLAN security setting option.
S.
Settings > Connection > Access Points > LAN (whatever yours is called) > WLAN security sett. > WEP key settings > WEP key
What could be simpler? Apart from everything.
robnash (love the spoonerism in your name, tell me its a joke and your parents werent that cruel) asked:
