Just bought TomTom navigator 6 software western europe and installed it on my computer but it will not reconise my Nokia N73... Please help.... I did some reading on this forum and it does work.... I Hope...:frown: :frown:
TomTom 6 will not reconise N73..... Help!!!
It won't recognise the phone if you connect it in "PC Suite Mode". You have to either use "Mass Storage" mode when you plug the phone into the computer (or just put the memory card in a card reader).
Then TomTom will either recognise it as a s60v3, or ask you what type of device it is, in which case you should put s60v3.
Thanks... i got it installed now.:redface: I am using a nokia LD-3W reciever. boots ok and works for about 2 mins then crashes the only thing i can do is press the red call end button to get off the screen freeze or says no signal... 😮
