The camera picture in camera fx is horrible compared to the normal 7650 camera, i did a picture test, here. The camera fx picture looks horrible.
Don't use camerafx
hmmm... you have a point. well, i use photographer. 8)
well yeah that's true, i use to have photographer but not anymore! i'm using the 7650 camera!
Well,try taking pictures with high quality set.Its not so bad.
That was the first time i posted anonymously. 😃
[quote="GhostDog"]That was the first time i posted anonymously. 😃[/quote]
Grrr...... :evil: :evil:
use photographer much better bro... :P
whats photographer ? can i have a download link
[quote="cyrax83"]The camera picture in camera fx is horrible compared to the normal 7650 camera, i did a picture test, here. The camera fx picture looks horrible.[/quote]
how dumb are you people i mean come on how can you say that software will give you a better pic its the hardware that makes it better all the software will do is change the colour/contrast but it wont actully make the pic any better (quality wise) ive done tests on all of the software and theres no diference atall so stop posting that some are better than others
xzibit..
you're neglecting the fact that nokias builtin photomanagment program might not be fully utilizing the hardware of the phone.
ick. *dies after noticing big-word overkill*
tsk... tsk... bad... dont ever call anybody dumb!!! :evil:
these people are just sharing their opinion, if you dont believe that then you can oppose and post your opinion here as well! but never call people dumb! :2gunfire:
about the issue, you're right in saying it is the hardware that makes the image quality better - and i agree, but i believe that the pupose of these apps is for enhancement after the image has been captured. im no techie but this is how i understand it.
anybody please correct me if im wrong, but dont call me dumb nor anybody else here! :evil: dont ruin the friendly atmosphere in this forum!!!! :evil:
sean
Ok. So you have done your tests on all the other Imaging softwares ei? So does it include you too?
Hi...
There is something called IMAGE PROCESSING in IT using which u can really UPgrade the quality of a picture a lot more......so, what if some of teh APIs of NOKIA supports some of Image PRocessing features? IMAGE PROCESSING is done lot in the software..and also what the apps like FhotoShop or things like that do? They can b used to Enhance the PIC Quality after 20 years of taking the pic.........so, with good programming it might b possible to upgrade image quality.......
[quote="kobe24"]Ok. So you have done your tests on all the other Imaging softwares ei? So does it include you too?[/quote]
huh? didnt get your question kobs. :-? im using Photographer and i believe - and have to say a good number of people here as well - that it can enhance the quality of the image somehow. 8)
i think what the program does, is refresh the frame rendering after you've taken it, which is why it takes longer to be processed and even when you zoom, its still as good. This i think, is the same in nightmode onthe 7650 camera, the lens continues to lap over the frames and so you're able to see more clearly. this is just what i think and could be totally wrong but i'm only 15 years old so leave me alone if i am wrong. 😊
Sorry Sean, that was meant for xzibit...
