Entering WPA password every single time?
4 replies · 3,153 views · Started 23 November 2006
This must be me being stupid, but where do I enter my Wi-Fi WPA password? Whenever I want to connect up, I select the access point and then I'm prompted for my 'preshared password'.....
Where's the field where I type this in so that I don't have to do this for every single connection?
Steve
menu > Tools > Settings > Connection > Access points
Create an access point there, and in the security settings for it, choose the correct security mechanism and enter the key ("password"😉 there, too.
Go into WLAN security settings. There, change the WPA/WPA2 setting from EAP to Pre-shared key. Then the Pre-shared Key option will activate where you can add your WPA key.
Damian
