N73 MUSIC EDITION firmware available!
77 replies · 124,627 views · Started 23 November 2006
Change your N73's product code to 0539343 and then use NSU to update your N73 to the Music Edition firmware.
There's a couple of new themes as well as the new Music App. to play with...
And it works very, very nicely indeed.
I've had this on my N73 for a few days. The music player is a definite improvement (although its not as good as the SE Walkman 2 player), the themes are nice.
Just need to get hold of a black cover and the ME keyboard now!
Have had my GPS unit, and HS820 headset connected, talking, giving me a route via TomTom, and no problems. Well good on yer, Nokia!
Is this exactly the same software but with an improved music player, i.e. nothing else lost?
Also, does this product code work with all network branded phones?
Yes, this is exactly the same firmware as 3.0638.0.0.1 other than the new music player, two new themes, and various small changes. No bug fixes above the "standard" v3 firmware.
The music player is completely re-written. Gone are those stupid round buttons crawling up the left of the screen. Now you get to use the joystick to control play / pause / forward / backward & stop. You also now get album art in your albums and tracks.
Found the way. Thanks. Its superv especially the music player similar to the n91. Should i have to change the code back to the original? Thanks again....
Another successful update here (from Orange to Music Edition).
Big thanks to everyone who posted "How To Guides" and Product codes 😊
Fab!!. at last .. a bit of violence !!
the code is fab!!!.. but a 75MB download was a bit!!.. evan with a 4MB adsl line!!....😞
fab thansk!! the media player looks like a real media player now.. not with daft buttons on teh left !
vinayakswamy wrote:Hey now the phone has a dedicated music button.Wow..... Should i have to change the product code to original?
What button becomes dedicated to the music player?
What do the new themes look like?
Many thanks
Bryan
Its the media button above the "C" key. Hated that button before, it was totally useless, now its quite usable.
Is there no way of changing the media key back to normal? I actually use it alot. Also is there any way of recording from the radio like on the n91? Can music tracks be changed by pressing the button on the headset? Lastly how do i change the code? Ok i think thats it. 😊
vinayakswamy wrote:Found the way. Thanks. Its superv especially the music player similar to the n91. Should i have to change the code back to the original? Thanks again....
how is that ?? mind to share ??
rickinson wrote:how is that ?? mind to share ??
A quick bit of searching will reveal a LOT of topics covering how you change the product code of the phone.
changed to n73 music edition useing product code 0539343 phone works ok only now i cant turn off the tone when useing camera has any one else had this problem thanks. Gary
Can somebody please tell me if i'm able to change tracks with the button on my headset in me. Also is recording from the radio possible? And finally if its possible to change the media keY back to normal instead of being a dedicated music button.
Thanx!
natanlevine wrote:Can somebody please tell me if i'm able to change tracks with the button on my headset in me. Also is recording from the radio possible? And finally if its possible to change the media keY back to normal instead of being a dedicated music button.
Thanx!
Change tracks? Nope. You have to buy the right headset for that (ie. HS20 - it has the play/pause, stop, ff, rewind controls. Also takes a standard 3.5mm headphone. I do kinda wish it worked like the SE volume control - hold down the key and you go to the next/prior track.
Radio recording? Nope. in fact, that feature seems to be getting removed slowly from other products that have previously supported it (ie. creative Zen)
Media key change? Nope. Then again, that darned shortcut button has a stupid animation that pops up, and it hardly makes things quicker.
Ok thanks. it's just that my last phone was a 3300 and I could record from radio as well as changing tracks on the headset. Oh well I suppose its not worth changing to ME as I seem to be the only one who actually likes the media key and old music player.
Does this ME upgrade get rid of all your applications, games etc like when the first firmware upgrade came out?
I really cant be bothered installing all my stuff again...
Nonsensical86 wrote:where do i go in order to change the product code? can any kind souls out there guide me? thanks.
Do a search of the N73 forum. There is Mucho Molto info out there ! 🙄
Search this forum and N80 forum for the word Nemesis.
natanlevine wrote:Is there no way of changing the media key back to normal? I actually use it alot. Also is there any way of recording from the radio like on the n91? Can music tracks be changed by pressing the button on the headset? Lastly how do i change the code? Ok i think thats it. 😊
there is also a verison 3 internet edition for n73 ,it great it got nokia n73 ME app+ few IM and net apps, and it includes english and Asian language, bold font, and the press the multimedia button takes the phone to shortcuts, instead of music app.
0539366
Is there a way to update to N73 ME without the use of the Internet?? just to pass the risk of getting disconnected while downloading like 60 MB at 128kb/sec if yes please let me know how.. and thanx.
saad3000 wrote:Is there a way to update to N73 ME without the use of the Internet?? just to pass the risk of getting disconnected while downloading like 60 MB at 128kb/sec if yes please let me know how.. and thanx.
NSU only performs the update on the phone once it has fully downloaded the update from the Nokia site, therefore, during the update of the phone, it shouldn't make any difference if you have it connected or not or if it drops out. Just make sure your PC doesn't get turned off or shut down 😊
