... Someone can tell me are can i get the cd it the symbian os series 60 sdk? I can find anithing on forum nokia and my pc does downloads at 1 kbs! So logicaly i can't not download that thing! Please tell me are can i get the cd,i really need it!!
Symbian os 60 sdk CD
An E mail/ Phone request to Nokia usually fetches it. (Free)
Yeah there's a form in the nokia dev to fill out then submit for approval. Once approved, they will send the CD to you.
I'm just waiting for mine then...I'll be posting some apps that I could do. That is I log off from AAS 😃
This is a message that you should get...
Hello,
Your request for Nokia Series 60 SDK has been approved.
The CD-rom will be sent to you by post. The shipment usually takes
about 1 week.
Best Regards
Developer Community
Nokia Mobile Phones
i thought you can download it from nokia.com ??? it's about 130 MB or something! correct me if i'm wrong!
[quote="Shadow"]i thought you can download it from nokia.com ??? it's about 130 MB or something! correct me if i'm wrong![/quote]
Yes. It very much can be downloaded. But his problem is a slow connection.
I found a place to order the CD on nokias site andit took about 2 weeks to get it so I think you can download it faster 😊
Dont remember exactly where but i think it was www.forum.nokia.com
Here is the exact link: http://www.forum.nokia.com/symbianforum/main/1,35452,1_32_12_50,00.html
I first try to download it from Nokia forum, but I use computer in my dormitory, and offten got offline here,every time when I've downloaded about 20~30% it will be reset😞122M is too big for me to download! Does anybody know whether I can order a CD from abroad? I've checked the web order feedback, it only require a street name and post code, but I'm in China, my address may be a little complicated😊Should I write my full address there? The window looks really small......I wrote a E-mail to them ,but they seems never want to reply, HELP!!
Yahoo!, I now have the CD straight from Finland...Now I only have to install my old Windows NT server.
Good thing it's Christmas holidays, ...I could now play with it. See the classes embedded on my phone.
Hei
U can use some DOWNLOAD Manager...........I sent the Sending Form, but still did not get any CD From NOKIA in 3 months....... :cry:
Thanks, but I've filled the form for a month, I don't believe they will send me a CD. Anyway, I've found another download place, though it is very slow, I spent a whole afternoon and successfully downloaded it, because it support downtools. But now there is Chinese version on the Nokia Forum site, I'm trying to download it, bless me!!
