N73 woes....
1 replies · 1,652 views · Started 23 November 2006
Hello all,
I have 2.0628.0.01
10.07.2006
RM-133
Nokia N73 ( 39.01)
I do have the vodaphone sim in .. but this phone is non branded.. I can use any sim etc etc...
I cant upgrade why?
The NSU cant find my phone.... which is odd as the nokia PC suite can see it ...via USB cable... so can nemesis or what ever its called...
a few mins after the NSU starts , it disconnect the phone ... then reconnects it...
Thus causing the NSU to freeze..... and loop .. trying to find phone...
I have used ever product code out there I can see..
Still wont work !!!... either says unable to find phone.. or once it said no software updates.. but that before I was changing codes...
as I said the odd thing is that the Nokia PC suite can see it .. and work fine.. all bar the NSU....
Any ideas????? has this happened to anyone else??
it's working..... I used code 0539343 hit the computer..... told it as going to take it to be made into coke cans....and it worked.... after one week ish now...it worked..
Mmmmmm
Dave
