Ok, so I know you need to type *0# at the beginning of a message to get a delivery report on O2, but what I was wondering was, is there anyway to make the phone automatically put this at the beginning of every text? Possibly using templates or something similar??
I am using an O2 branded Nokia N80 with V4.0623.0.42 20-09-2006 RM-92 Nokia N80 (33.01).
yeah exactly that... if you make a *0# template and then create a new message, when you at the text field you can go : OPTIONS > INSERT and pic your template from there....
then your message will start *0#
Doesn't O2 support the standard delivery reports, which you can enable for all messages in the "Messaging" app settings?
never did before, not on O2 on this N80 so cant retest...
but it would be faster to just type the *0#
no o2 networks never had the standard delivery reports. *0# is what i got told to do by customer services though
cos if that was allways set on it would piss alot of customers off , its not like a normal report that say voda etc have , when it comes to the fone its like a normal text to you 012345679 has recieved yer msg "what u doing tonight........................." etc , it actually includes partial yer original text
