update joy !
2 replies · 1,696 views · Started 25 November 2006
And so the saga continues..
Upgrade to the media version... fab .. all fine... BAR
on my SD card was all these apps.... they have all installed themselves bar one....
OPERA!!!!!
😞 I have looked in App Manager..
and there is it .. on the top..( not installed ) when i try to it says.. corrupt file on card ..
How can i delete this entry in the app manager ... as every time the phone starts up... it tries to install opera!...
I have looked every where on there phone... 😞
david
Reinstall it (or if it was installed on the memory card, as you say, connect to a PC in USB mass storage/data transfer mode and delete the files from the card using your PC).
"Reinstall it (or if it was installed on the memory card, as you say, connect to a PC in USB mass storage/data transfer mode and delete the files from the card using your PC)."
I have reinstalled it.. still comes up with file error ..corrupt.
and that getting it from opera's site..
I have installed opera ( mini ) now...thats fine for the amount of " surfing I do ...
I have taken the card out , and looked at it on my phone.. taken out all the opera ref's .. phone error still pops up!!!!!!
Does any one know how to take the entry's out of the app manager ?
thanks..
