I had 20 themes on my N73,yesterday is did a softwareudate,after that i was installibg al my themes again but.......
Some of them i can not install,the phone says.......can not install...or not gog updated....???
I had them all on my phone before the software update???? and now they are doing difficult????(some of them)
i am getting crazy!!
Is strange... Before install again new things, and, I know You have do the upgrade, but, before do a phone format *#7370#. Try again.
nj7 wrote:Is strange... Before install again new things, and, I know You have do the upgrade, but, before do a phone format *#7370#. Try again.
I already did that yesterday
How do You try to install? From card or from PCSuite? After upgrade, the card inside phone have been formated again?
nj7 wrote:How do You try to install? From card or from PCSuite? After upgrade, the card inside phone have been formated again?
No the mmc was not formated only the phone,i formated the mmc myself,but i think i know what happend.
When i was installing a new theme my phone spontaniosly went to the nokia standard theme???? from that moment on i colud install every theme😊 i have them all again on my phone now,yes!!
So when i am going to instal any apps or themes i select the nokia bleu standerd theme.
Try format the card again inside the phone. And install by PCSuite... Maybe after format, is the same, if installed with the file on card.
nj7 wrote:Try format the card again inside the phone. And install by PCSuite... Maybe after format, is the same, if installed with the file on card.
I did instal by PC suite but also by BT it works both ways,usualy i dont use the PC suite i do everything by BT directly to phone.
But as a told here,it works fine now.
