ok ive noticed that when i take a picture and send it via a msg, it it recieved as as basically a 'thumbnail' of the picture. Is there any way i can send it as the bigger original size.
It isnt the reicievers phone that is the problem, they have a new nokia too (dont know the model but it is like the n80 - its a slider and sorta looks the same)
When i recieve picture msgs they come through as original size, i just dont know why whenever i send one, it is sent so small.
Is there a setting where i can change this?
fishman_ wrote:ok ive noticed that when i take a picture and send it via a msg, it it recieved as as basically a 'thumbnail' of the picture. Is there any way i can send it as the bigger original size.It isnt the reicievers phone that is the problem, they have a new nokia too (dont know the model but it is like the n80 - its a slider and sorta looks the same)
Do a search in the forum dude...its been discussed several times and I think you will find your answer quicker
There is a network limitation. When is send, is an MMS, and is limited to 100kb or more or less that value, it depends from network and from data plan subscript, but is always limited. Send instead an email!
