n73 Joystick
5 replies · 5,847 views · Started 26 November 2006
[SIZE="2"]I read in some reviews that the n73 joystick is a bit of a problem. Is this true? They say it's a bit buried on the phone. If so, do you guys know any do-it-yourself tips so that we can make the joystick standout more on the phone for easier usage?[/SIZE]
I bought my n73 under the assumption that joysticks are not good but i'd have to get used to it. I'm happy to say that my joystick has been very comfortable with many advantages over a 5d pad
Hi Guys
I had the same problem when i bought my new N73 and after awhile it became so easy to use tha joystick but few days later ...... i lost the botton that is on the Joy stick it self but I found it so I thought that the booton is not fixed correctly so what I did ......?
i tried to put it on again .........I puch it down gentely but the joystick stucked in and never gomes up agian this is so bad so be carfule when you use it Or you can use th e boton instate of the joystick this how I'm using my N73
I look for aparepart but hey said it's not availble now
Hi Guys
I look for spare part but hey said it's not availble now
