I'm depress, after a weekend fighting with my new toy/phone, I wanna give up, cant take no more!
I bought the 7650 because the camera, but if to send a picture I have to do a master on computering..hey!
I'm sorry guys but 80% of the stuff that you are talking about is Japaness for me. I JUST WANT TO SEND PICTURES!!
When I send mms to a email adress it works ok.
But if I send a mms to another 7650, my picture stays in my Report file as "Pending" and never reach the other phone, why? why? why?
please help, I really like my 7650...
depression
Have you checked with your Message Settings in the Multimedia message. You should clearly define there the access point that was given to you by O2
invalid preferred multimedia acces point!!!
how can I fix that?
Make sure that the access point that you select is the MMS access point assigned to you by O2.
Check it from the Tools>Settings>Connection>...find the MMS access point. Make sure that is correct.
After this go back to the Message Settings.
Or, Call your O2 for help on the settings.
The steps below are for Globe Telecomms, Philippines. I am sure it is similar to your settings, except for the Nokia 7650
Go to the desktop/main menu by pressing the Menu key
In the main menu, go to Messaging and press the joystick to open the folder
Press Options, then choose Settings
Choose Multimedia message
Choose Preferred connection
In the Default access point screen, press Options � New access point � Use default settings
Connection name - GlobeMMS
Data bearer - GPRS
Access point name: mms.globe.com.ph
Gateway IP address - 192.40.100.20
Homepage - http://192.40.100.22:10021/mmsc
Session mode - Permanent
Press Back button and the settings are saved
Choose GlobeMMS as the default access point
[code:1]
Nokia 7650
Data bearer - GPRS
[/code:1]
[quote="ziggypop"]invalid preferred multimedia acces point!!!
how can I fix that?[/quote]
Ask o2 to send out the MMS configuration settings to your phone - when u recieve it, open it and choose the option to save settings - once u don that retry - It might not work but its the first step [Very VERY easy to set up, we'll, well i'll guide you! The 7650 is a fine device! Much easyer than the other ones around!]
Guys,how do you know that he is on O2?
ziggypop,does your operator support MMS? If you are not sure ask them about it.
If it does,tell them about your problem over the phone or go to one of theirs service points and they will od it for you?
From another post... http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=5732
