Upgrading Firmware for Nokia N80
3 replies · 3,097 views · Started 27 November 2006
Hello,
Could somebody please help me,
I have just bought a new Sim Free Nokia N80 and it is running the V3 software. Can someone tell me where I can go to get it updated.(I live near Leeds, UK)
I have tried to update it by the 'Nokia Software Updater' it just it just hangs on the 'Detecting Phone' part.
When I attach the cable the phone asks which application I want to use i.e, PC Suite, Data Transfer and a couple of others.
Which option do I choose when I attach the phone because there is no option for 'Software Update'
Thank You in advance,
felixcatster1😊 😊
felixcatster1 wrote:Hello,
felixcatster1😊 😊
Go to the following Nokia UK website to locate the nearest Nokia Service Centre:
http://www.apps.nokia.co.uk/clubnokiaservice/
Looks like there are two to choose from in Leeds.
S.
p.s. You should have posted this in the N80 section as opposed to the N70 section. 😛
p.p.s. You need to use the 'PC Suite' option when connecting the USB cable.
Hi Steve,
Thank You very much for your reply.
I have looked at the page you suggested and yes there are two Nokia Service Centres and I am pretty close to both.
If I get no joy from trying the Nokia Soiftware Updater online, one more time,
I'll be taking a trip to one the the Nokia Centre's.
Sorry for posting on the wrong board will get the right board next time😊 😊
Cheers again S
From felix😊 😊
felixcatster1 wrote:Hi Steve,
Cheers again S
From felix😊 😊
No worries mate 😊
Good luck!
S.
